Revvaloon Posted June 13, 2020 Share Posted June 13, 2020 The sound goes away when I use an allen key and unwind it, but then the pedal gets abit too loose for my liking. Does anyone have suggestions on how to fix this? I understand there is a post on how to maintain the Helix pedal but it also mentions that it not meant to be used for the LT? Thanks. Quote Link to comment Share on other sites More sharing options...
j_hotch Posted June 13, 2020 Share Posted June 13, 2020 I used some synthetic bicycle chain lube on mine, applied right around the friction point. Quote Link to comment Share on other sites More sharing options...
Revvaloon Posted June 14, 2020 Author Share Posted June 14, 2020 9 hours ago, j_hotch said: I used some synthetic bicycle chain lube on mine, applied right around the friction point. Did you remove the allen key before you could access the friction point? It seems slightly far in to reach the friction point. Quote Link to comment Share on other sites More sharing options...
j_hotch Posted June 15, 2020 Share Posted June 15, 2020 IIRC, I loosened the Allen screw enough to let the pedal slide sideways and allow access to the friction point. I used a long-stemmed swab to apply it. Quote Link to comment Share on other sites More sharing options...
