mapix Posted June 18, 2020 Share Posted June 18, 2020 Hi, after updating to 2.92 I cannot find anymore in the command center how to change the label of the foot switch I want to use to select a snapshot! The filed "customize", where you can modify the label name, is disappeared!! How can you change the label now, please? Quote Link to comment Share on other sites More sharing options...
phil_m Posted June 18, 2020 Share Posted June 18, 2020 What specific product are you talking about? It still shows up in my Helix Rack. Quote Link to comment Share on other sites More sharing options...
mapix Posted June 19, 2020 Author Share Posted June 19, 2020 Helix floor, pls see the attached snapshot Quote Link to comment Share on other sites More sharing options...
Melissiah Posted June 19, 2020 Share Posted June 19, 2020 Same for me but I found a way to cheat this. I choose the color and name on another parameter. The one before helix preset. And when you switch back to preset up or snapshot, the name and color remains. I’ll join a picture after work. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted June 20, 2020 Share Posted June 20, 2020 Name your Snapshots the normal way, on the main screen using "Rename". The Snapshot you choose for the PRESS function will be the name on the Scribble Strip. I don't remember the details, but I seem to recall that the Customize function was causing a problem, so they removed it. Quote Link to comment Share on other sites More sharing options...
phil_m Posted June 20, 2020 Share Posted June 20, 2020 Are you sure you're using the latest version of HX Edit (2.92)? I went and checked this again in HX Edit with my Rack, and it's still showing up... Quote Link to comment Share on other sites More sharing options...
rd2rk Posted June 20, 2020 Share Posted June 20, 2020 I'm definitely on 2.92 (?,ABOUT), and it's not there (Floor). Quote Link to comment Share on other sites More sharing options...
Tyguy1995 Posted November 24, 2020 Share Posted November 24, 2020 Anybody found a solution to this? Using the most recent version of hx edit and I have this same issue. Quote Link to comment Share on other sites More sharing options...
Melissiah Posted November 24, 2020 Share Posted November 24, 2020 7 hours ago, Tyguy1995 said: Anybody found a solution to this? Using the most recent version of hx edit and I have this same issue. Use my cheat, that bug isnt fixed yet I choose the color and name on another parameter. The one before helix preset. And when you switch back to preset up or snapshot, the name and color remains. Quote Link to comment Share on other sites More sharing options...
Tyguy1995 Posted December 1, 2020 Share Posted December 1, 2020 If possible, can you upload that picture you were talking about? Not sure I'm quite understanding what "the one (parameter I'm assuming) before helix preset" means exactly. Quote Link to comment Share on other sites More sharing options...
