tagomago1979 Posted June 28, 2020 Share Posted June 28, 2020 Hi there I have a Steinberg UR22mkII USB audio interface that I use for my PC WIN10. I just bought the POD Go and I can't use that interface as a audio output for the PC AND the POD Go. I can use the POD go as a replacement, using it just as a soundcard, but it is a bit annoying changing configuration everytime I take the POD GO to another place. What I'd like to do: - Using the guitar input of the POD Go. - Having it connected via USB to my PC. - Using my existing audio interface as the audio output for the POD Go and everything else. When I select my audio interface as audio out in WIN10 there is no sound of the POD Go coming out. What to do? Quote Link to comment Share on other sites More sharing options...
silverhead Posted June 28, 2020 Share Posted June 28, 2020 What you are experiencing is normal and due to the technical specification of the ASIO protocol which is used by Line 6 and and many other audio devices and programs. Under ASIO there can be only one audio device in use at a time, by either your PC or your DAW, and it must be both the audio input and output device. So you can’t use the POD Go as input and your other audio interface as output. You have a choice: either continue to use your other audio interface and connect the POD Go’s audio outputs to its inputs (I.e. no POD Go USB connection), or remove your other audio interface from the setup and use the POD Go as the audio interface device, for both input and output. In this case you would connect your speakers/headphones to the Pod Go outputs. Another strategy that some people use, which I do not recommend, is using a non-ASIO, or pseudo-ASIO, driver that supports different audio input and output devices. A popular one seems to be ASIO4ALL. However, since it is not a true ASIO driver it is not supported by Line 6 for use with its devices, and is known to lead to unpredictable problems depending on the PC environment in which it is being used. Quote Link to comment Share on other sites More sharing options...
tagomago1979 Posted June 28, 2020 Author Share Posted June 28, 2020 Thank you! I guess you are correct as ASIO was always a bit stiff in this regard. Have a nice day! Quote Link to comment Share on other sites More sharing options...
dprovince Posted January 30, 2022 Share Posted January 30, 2022 Would he/we still be able to use the usb connection in order to use pod edit? Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 31, 2022 Share Posted January 31, 2022 Yes, you can use the USB connection to run both a DAW (recording program) and Pod GO Edit simultaneously. Quote Link to comment Share on other sites More sharing options...
dprovince Posted January 31, 2022 Share Posted January 31, 2022 Sorry my question was if you used the pod go with the audio interface to run the daw (Ableton) could you still use the USB connection to run the pod edit? Therefore eliminating the need to switch back-and-forth. While still having control of the pod go with the edit software. Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 31, 2022 Share Posted January 31, 2022 Ummm, yeah. that’s the question I answered. You can do that. Quote Link to comment Share on other sites More sharing options...
Guitar55 Posted August 12, 2023 Share Posted August 12, 2023 On 1/30/2022 at 9:52 PM, silverhead said: Yes, you can use the USB connection to run both a DAW (recording program) and Pod GO Edit simultaneously. When I use the Main output of my Pod Go into my Focusrite interface AND have USB connected so I can use Pod Edit at the same time, I get a terrible buzz (ground loop?). Is there a way to fix that? Quote Link to comment Share on other sites More sharing options...
