jeremystern Posted July 2, 2020 Share Posted July 2, 2020 Hi, I downloaded and modified a tone from CustomTone, Go-To AC30, and when I press the volume pedal all the way heel down I still have a lot of signal coming through. I've checked the rest of the patch but can't seem to get it going to 0 on heel down (even though it says 0). Any ideas? Thanks! Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted July 2, 2020 Share Posted July 2, 2020 Patches sometimes get corrupted, and Customtone is the wild west... you never know what kind of mangled junk you're gonna end up with. If the pedal is properly calibrated and works as advertised with other patches, then there's something wrong with the patch you downloaded, and you might not get it to work right. If you're really in love with the tone, start from scratch...try rebuilding the patch in an empty slot, one block at a time, but don't copy and paste from the one that isn't working. After each block is added, try the volume pedal and see when/if it starts to malfunction. 1 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted July 2, 2020 Share Posted July 2, 2020 Move the Path B split to the right, AFTER the Volume pedal. 1 1 Quote Link to comment Share on other sites More sharing options...
jeremystern Posted July 2, 2020 Author Share Posted July 2, 2020 11 hours ago, rd2rk said: Move the Path B split to the right, AFTER the Volume pedal. Works like a charm!!! Thanks so much! I did the same with the wah and that fixed another issue I was having. I really appreciate your help. Quote Link to comment Share on other sites More sharing options...
