MEP1603 Posted July 4, 2020 Share Posted July 4, 2020 Hi there, I'm a bass player; I noticed that if I put the Tron Up filter in my signal path it seems to suck some low end when bypassed. Has anyone else had the same experience? Thank you & happy 4th! Quote Link to comment Share on other sites More sharing options...
rd2rk Posted July 4, 2020 Share Posted July 4, 2020 No. Here's a test Preset. Press FS11 to A/B the two signal paths. Maybe there's something else in your signal path that's causing it. Test Bypass Tron.hlx 1 Quote Link to comment Share on other sites More sharing options...
MEP1603 Posted July 4, 2020 Author Share Posted July 4, 2020 Thanks much, will check it out! Quote Link to comment Share on other sites More sharing options...
CraigGT Posted July 5, 2020 Share Posted July 5, 2020 It could do if you have the I/P impedance set to auto and the Tron simulates a different value to the standard 1M Craig Quote Link to comment Share on other sites More sharing options...
rd2rk Posted July 5, 2020 Share Posted July 5, 2020 32 minutes ago, CraigGT said: It could do if you have the I/P impedance set to auto and the Tron simulates a different value to the standard 1M Craig https://www.mu-tron.com/vintage-musitronics/mu-tron-iii/ Input Impedance: 1 megohm at lowest setting of GAIN control, variable to 3.3K ohms at maximum gain setting Quote Link to comment Share on other sites More sharing options...
CraigGT Posted July 6, 2020 Share Posted July 6, 2020 The easiest fix is to set the input impedance for the patch to 1M. Craig Quote Link to comment Share on other sites More sharing options...
MEP1603 Posted July 6, 2020 Author Share Posted July 6, 2020 Thank you! Quote Link to comment Share on other sites More sharing options...
CraigGT Posted July 7, 2020 Share Posted July 7, 2020 23 hours ago, MEP1603 said: Thank you! You're welcome, There's lots of threads on here about Helix's input impedance settings and it's expected (and unexpected) consequences. Craig Quote Link to comment Share on other sites More sharing options...
