scottwilliams Posted July 10, 2020 Share Posted July 10, 2020 Hi - very happy to be able to put looper controls into a preset using command center! i used it at gig and went well, but realized i needed one more looper control. (since I sometimes have to record a section to solo over later, it's important to be able to use STOP to end the loop so it's ready when i need later in the song) Now have Undo, Rec/OD, Play, Stop problem is that my play and stop switches have to be pushed twice to respond.. i can't figure out anything wrong in the settings. after recording a loop, the buttons seem to work ok the first time, but if i stop the loop, then it takes 2 pushes on play to play it and then 2 pushes on stop to stop it. Any assistance would be much appreciated! Quote Link to comment Share on other sites More sharing options...
cglaser68 Posted July 13, 2020 Share Posted July 13, 2020 I have this issue for two snapshots. So, I don’t think this is a looper issue per se, but something with command center. What’s strange is that the double press issue only happen when going from certain snapshots to certain other snapshots. I.e Our band does ‘I Ran’ by Flock of Seagulls. So I have the following snapshots: Footswitch 2: Intro tone Footswitch 3: Solo tone footswitch 8: verse delay tone footswitch 9: verse clean tone if I I’m on the footswitch 8 tone and then want to go to the footswitch 3 tone, I need to press footswitch 3 two time for the snapshot to activate. However, if I’m on the footswitch 9 tone, and go to the footswitch 3 tone, I only need to push footswitch 3 once for it to activate. I can’t figure it out. Ive tried dong a full factory reset and restore from backup, but that did not fix. In command center all the settings look fine. This started for me after going to firmware 2.91. Quote Link to comment Share on other sites More sharing options...
