How to assign and edit multiple min/max values.
grdGo33
Ok figured it out while typing this and testing for like an hour, but it was quite frustrating, so in case it helps someone... If you want to add/edit multiple min/max values to a footswitch.  Manual states:
So to create:
1) hold a knob
2) press learn
3) press the footswitch (here, values reset to 0-10, annoying but normal)
4) you can alter different parameters to set min/max, but you still need to specify the footswitch for every setting, which is annoying, but necessary...
5) press view to exit, no save required or any other switch/learn required to save
here you should see something like "Multiple(2)" for your pedal assignment if you switch views, and if you press the switch it should change between the values
6) save 'normally' so your saves are saved if you switch patches
To edit, same thing as above, but skip the steps #2 and #3:
1) hold a knob
2) change the different values you need to change (you don't need to press learn or footswitch before!)
3) press view to exit, no save required or any other switch/learn required to save
4) save 'normally' so your saves are saved if you switch patches
This could have been clearer in the manual...
