Jgc5
Hx effects Preset template?
Are there templates for creating new blank 4cm presets or any type of shortcut? Sorry if this question seems basic. Only had the unit for 3 days and still figuring things out.
Thanks
They tend to recommend just starting with a 4cm preset in the box already and altering it. I am in the process of watching Peach Guitars multi episode Youtube videos on using the HXEdit software to program up your HX Effects. I have learned more from those videos than I did in a year of limping along .Please go check them out, they are the best instruction you can get right now, and Jack goes over how to set up a patch from scratch, then he demonstrates the hows and why's of doing up the patch for 4 cable method. Literally, that series is entirely responsible for clearing the HX fog I have had since buying the unit over a year ago. I wish that series of videos shipped with the unit or was prominently linked to from this site.
Thanks
There is supposed to be a Template on the HX Effects for 4CM. This is an excerpt from a  post from Line6's DigitalIgloo:
So HX Effects supports 4-Cable Method?
There are two mono effects loops (or one stereo effects loop) for inserting your favorite pedals anywhere into HX Effects' signal flow and/or connecting to your amp(s) via 4CM or 7CM. There are even templates to get you started.  Don't own an HX Effects but if it is anything like the Helix it should be in the Templates setlist.
