Volume pedal
ezut
Hi there. There is a problem that when changing presets, the new preset always comes in at full volume. This is not always good. On my old POD HD300 pedal, this did not work. It brought the volume level to the same position as the pedal was when switching. Is there a global setting for Helix to switch like this?
Set the Global Settings 'EXP Pedals' --> 'EXP Pedal 2' = "Global" if you want all your presets to reflect the current position of the expression pedal. Assuming there is a volume pedal block in the presets and it is assigned to EXP 2(the default).  There is also a 'Per Preset' and 'Per Snapshot' setting available.
  • Thanks 1
