foofighterux2 Posted July 31, 2020 Share Posted July 31, 2020 podfarm vst in ableton and logic x will not work with shortboard mk11.what ive discovered is that if I open ableton and arm an audio track then open podfarm standalone I can hear for example the distortion. I can record it in ableton but when I play it back the tone is clean.if I then drop vst podfarm on that track with same setting as standalone ie:comfortably numb it works.all I want to do is use shortboard mk11 to control presets up and down and wah.i can set wah to work vst but not presets.can anyone please tell me how to set up scrolling in vst podfarm 2.5? Standalone works with podfarm and amplitube but not in ableton or lo gic x many thanks guys. Quote Link to comment Share on other sites More sharing options...
foofighterux2 Posted July 31, 2020 Author Share Posted July 31, 2020 I read on here about licence for podfarm 2.5 is only active with ux2? I have axe io ik multimedia.will vst podfarm not work with axe io in ableton for example thank you? Quote Link to comment Share on other sites More sharing options...
Triryche Posted July 31, 2020 Share Posted July 31, 2020 PF2 should work as a plug-in in your DAW if the UX2 is connected and recognized. To use PF2 standalone with a non-Line6 interface would require the hardware independent license. Quote Link to comment Share on other sites More sharing options...
