wambli1 0 Posted February 11, 2014 How do I set 500x for my guitar and use for vocal effects? Is there patches already in rig for vocals? Is there a PDF of patch/ settings listings? Quote Share this post Link to post Share on other sites
Zhorell 3 Posted February 11, 2014 Do u mean using guitar and mic for vocals simultaneously? I'd like to know that too if that's possible with 500x? Quote Share this post Link to post Share on other sites
silverhead 8,817 Posted February 11, 2014 Here is a patch that illustrates using guitar and vocals simultaneously, with completely separate processing, in the HD500. http://line6.com/customtone/tone/215659 Quote Share this post Link to post Share on other sites
wambli1 0 Posted February 11, 2014 Thank you. How do I change guitar preset? I am using 500x Quote Share this post Link to post Share on other sites
wambli1 0 Posted February 11, 2014 How did you get it to split up into two? I bought some presets that i would like to use as is what having to re-program effect strips/channels. Right now they have only one strip/channel. Do I make changes in Edit or the effects pedal/floor unit? Not lazy, have been reading advanced guide but just can't seem to find that part Quote Share this post Link to post Share on other sites
silverhead 8,817 Posted February 11, 2014 To change the guitar path of the signal just change the selected amp and FX models. To create a dual path preset with independent processing: - select the amp in the single path setup, then hit the Move button followed by the Down arrow. This will cause a second amp to appear in Path B. - move all FX blocks so that they appear in one path or the other - AFTER the path split. The two paths will only be processed independently if there is nothing before the path split. Input 1 will be routed through Path A, and Input 2 through Path B. You can do this both on the device itself, or using Edit (easier IMHO). Quote Share this post Link to post Share on other sites
