mikelynch229 0 Posted August 4, 2020 I have having an issue when I am using a hot guitar the POD HD will breakup on attack and as the strings ring, the sound clears up. This especially happens with my Les Paul as opposed to my Strat. Is this normal or is there something going on with my unit? Thanks - Mike Quote Share this post Link to post Share on other sites
pianoguyy 416 Posted August 5, 2020 yes, there are settings for that. unless you have a faulty unit and are hearing something else which coincidentally mimics a regularly occurring thing. Quote Share this post Link to post Share on other sites
hurghanico 1,462 Posted August 5, 2020 3 hours ago, mikelynch229 said: I have having an issue when I am using a hot guitar the POD HD will breakup on attack and as the strings ring, the sound clears up. This especially happens with my Les Paul as opposed to my Strat. Is this normal or is there something going on with my unit? Les Paul and other humbucker PU equipped guitars are not only hotter than single coil PU equipped guitars, but their low end is so big that if not lowered in some way can easily cause unwanted bad distortion in the next thing in the chain. The POD models in particular are very sensitive (maybe too much) to strong bass frequencies in the input signal therefore I suggest to reduce their level as needed with the available controls to get a better balanced tone and a cleaner attack. If instead the problem is a kind of dissonant ghost notes that overlap the normal ones as they decay, the issue can be solved by lowering the amp models HUM parameter. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Share this post Link to post Share on other sites
DolurumMafikala 3 Posted August 5, 2020 As well as Hurghanico's points, the Pod HD default input settings can cause your input signal to be hotter than you might intend. There is a thread about it here: https://uk.line6.com/supportarchivenew/thread/74045/ and the MeAmBobbo Guide talks about it here: http://foobazaar.com/podhd/toneGuide/setup#input If you want to try that quickly, take one of your patches with your LP and set Input 2 Source to Variax (or mic - something you are not using) and see if that cools your input. DM Quote Share this post Link to post Share on other sites
DaVinciVanGogh 0 Posted August 6, 2020 I'm new to this and I'm having a difficult time navigating my way around. I was wondering if I could ask an unrelated question on my quest in this endeavor? Q: Will the Bass Pod XT footboard control the rack mount Pod XT Pro or are the dark pink one and the black one or are they entirely different units and thus incompatible? Quote Share this post Link to post Share on other sites
mikelynch229 0 Posted August 8, 2020 Thanks for the quick responses. Changed input 2 to variax and my rig now sounds great! Quote Share this post Link to post Share on other sites
DolurumMafikala 3 Posted August 12, 2020 Glad it helped. Hurghanico's points are all still valid, and offer you more control. If you hear unwanted clipping again you can reduce gain on the individual models in your chain. DM Quote Share this post Link to post Share on other sites
titchyblackcat 23 Posted September 28, 2020 Which Les Paul do you have ? I had a Les Paul Studio which i could never get a decent clean sound from. I sold it and now have a Les Paul Traditional which sounds OK Remember these amp modellers are like amps. If your guitar sounds bad you'll get something that's louder bad. Quote Share this post Link to post Share on other sites
