MathisMade Posted August 13, 2020 Share Posted August 13, 2020 I would love to use the HX effects to control the parameters of the Iridium. Example: have a clean and then a overdriven sound(which is controlled via MIDI) I contacted Strymon on this and they said it would have to be controlled via MIDI CC. Would anyone know how to do this? I have been trying to wrap my head around this and can't :( I have all the necessary cables to make it happen. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
fairleas Posted August 13, 2020 Share Posted August 13, 2020 I don't own an HX FX but a quick look at the manual seems to suggest it doesn't generate CC messages. You would need to control both the HX and the Irridium with an external MIDI device from what I can see. Edit: The Irridium is awesome BTW, I love mine. Quote Link to comment Share on other sites More sharing options...
iamdavehart Posted August 13, 2020 Share Posted August 13, 2020 Look in the manual at the Command Center options. Page 35. https://line6.com/data/6/0a020a3d3f4a5a6a1897ecdf6/application/pdf/HX Effects 2.50 Owners Manual - English .pdf That shows you how to send MIDI CC settings. For the iridium you would need a cable that converts the 5 pin midi to a TRS plug. strymon sell one, and it sounds like you've got one. Helix and HX Effects have command center HX Stomp does not as far as I know. 1 Quote Link to comment Share on other sites More sharing options...
fairleas Posted August 13, 2020 Share Posted August 13, 2020 I hadn’t seen that. Thanks, stored for future reference. Quote Link to comment Share on other sites More sharing options...
