DWoody Posted August 14, 2020 Share Posted August 14, 2020 I playguitar at church and practice at home with Planning Center/Multitracks. Had my helix about a year and ahalf, downloaded many patches and have loved it! So just the other night it just went silent and i've checked the cable from guitar to the helix, the cable to the amp from the helix, and volumn knobs, pedals etc... Please can someone help? Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 14, 2020 Share Posted August 14, 2020 You'll need to open up a support ticket: https://line6.com/support/tickets/add.html If you activate the tuner, does it respond to the guitar plugged into the input? Quote Link to comment Share on other sites More sharing options...
datacommando Posted August 14, 2020 Share Posted August 14, 2020 (edited) 43 minutes ago, DWoody said: Please can someone help? Line 6 added input and output indicator bars to the recent firmware. I advise that you check that you are actually getting a signal from your guitar into your Helix and then that the signal Is getting as far is the output. Add a compressor block to see if the meters react on that. After that it will be a process of elimination as to where the signal is going, does it come through to the XLRs or from the USB for example. When all else fails - raise a ticket as “phil_m” suggests in the post above. Edited August 14, 2020 by datacommando 1 Quote Link to comment Share on other sites More sharing options...
