willyjacksonjs22 Posted August 18, 2020 Share Posted August 18, 2020 On my hx stomp when playing trough, everything sounds fine it’s just the recordings that sound weak and muffled ( clean tones and edge to break up tones) High gains are so so ok. I’m using the hx stomp as an audio interface. Recording in the 48 rate Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 18, 2020 Share Posted August 18, 2020 Are you monitoring the recorded tones through the same speakers that you used while recording them? The playback should be identical to what you were hearing while playing. One thing that can affect that is the Global EQ, though. The Global EQ doesn’t affect the USB out, so if you have it on, it would affect the sound coming from your speakers, but not the recording. 1 Quote Link to comment Share on other sites More sharing options...
willyjacksonjs22 Posted August 18, 2020 Author Share Posted August 18, 2020 51 minutes ago, phil_m said: Are you monitoring the recorded tones through the same speakers that you used while recording them? The playback should be identical to what you were hearing while playing. One thing that can affect that is the Global EQ, though. The Global EQ doesn’t affect the USB out, so if you have it on, it would affect the sound coming from your speakers, but not the recording. Yes same speakers. Thanks I’ll check global eq Quote Link to comment Share on other sites More sharing options...
