Looper settings
Samleyde
When you use the looper, and want to delete what you've looped, you have to hold down the switch to delete but it plays 1 second of what you looped while it deletes.
Does anyone know if there's a way to turn that off?
I use the Pod Go for live solo acoustic gigs and it's super annoying.
I have a delay/looper that has the same sort of bug, so I guess it's a design thing, when there's multiple functions assign to the same switch. As a workaround you could shut off your volume pedal while you are deleting the loop, then get it back to toe position. If turns out that it's a bug you may submit a support ticket to line 6.
