Looper
GZW004
2 hours ago, GZW004 said:
Why is not with every patch the looper in the list available?
It's not clear what you mean.
If you mean "why isn't there a looper in all the patches?" then it's just a patch so you can modify it by adding a looper.
If you mean that you see patches where you cannot add a looper, it's probably that there are already too many blocks in the same line, or to many super consuming blocks. Basically think about the top and bottom lines are 2 processors, they need to be able to process the audio of what you make them work with. Helix will prevent you from adding more work than that processor can work with.
You can fix this either by removing another block, or by serializing both processors: make the output block of the top line go to the input block of the second line. Then you need to move the blocks to balacne the work on both processors.
  • Upvote 2
On 8/25/2020 at 4:05 AM, Dogaral said:
oh cool this has a looper ?  learn something new every time I come here
Yeah it's a basic looper, not too long memory, have some functionalities, works well for pratice and simple songs.
It's recommended to get a looper pedal if you want more advanced looper features.
