microtoneaudio
Pod Go Main Out - tolerant of phantom power, or not?
I intend to use a TRS 1/4" > XLR adapter cable for a balanced connection to mixer. Is Pod Go at risk if there's phantom power coming from the mixer? Or is it safer to use a DI box?
Thanks in advance for any assistance with this. Cheers:-)
I've never had any problem using phantom power from the mixer to the various instruments that may be connected. Phantom power should not damage any equipment if it's connected via a balanced cable, which is general standard because 99% of mics have all XLR connection, and other devices most probably too, and if they're not you put a DI in between. So with the TRS>XLR adapter you should be fine, or, use a short standard mono (instrument) cable from the main out to a DI, and from there to the mixer with XLR cable.
