medved_wanders Posted August 25, 2020 Share Posted August 25, 2020 I am a total noob and trying to understand how to change mapping of blocks to foot switches. I previously had PodGo and there I could actually hit a menu that showed switch layout and I could change it easily. Tried various menus and right clicks in HX Edit, but cannot figure it out Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 25, 2020 Share Posted August 25, 2020 In the HX Edit window immediately below the signal flow display you will see two tabs, one called EDIT and the other called CONTROLLERS or something. Hit the CONTROLLERS tab. You should be able to figure it out from there I think. Of course, there’s always the HX Edit manual..... ;-) Quote Link to comment Share on other sites More sharing options...
medved_wanders Posted August 25, 2020 Author Share Posted August 25, 2020 Yep, its a tab right next to Edit tab. Thank you :) Quote Link to comment Share on other sites More sharing options...
medved_wanders Posted August 25, 2020 Author Share Posted August 25, 2020 One more question... I see switch 7 being an option to map to, but on the HX itself that switch displays MODE switch. Is there a way to use for a block? Quote Link to comment Share on other sites More sharing options...
silverhead Posted August 25, 2020 Share Posted August 25, 2020 To answer this question I would need to consult the manual. I keep a copy handy at all times, and it might help you too. Teach a man to fish, as they say.... Here's the link for your convenience. https://line6.com/data/6/0a06439c975d5787c3e351aa0/application/pdf/Helix 2.0 Owners Manual - Rev D - English .pdf Now, anticipating a backlash from those who think a response like RTFM is rude, please acknowledge that he is essentially asking others to do that for him. Note that I had gently recommended the manual in my previous post in this thread. Gentility was apparently ineffective. Perhaps a 2x4 to the forehead.... ;-) Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 25, 2020 Share Posted August 25, 2020 HX Edit doesn’t really have the same sort of footswitch for normal bypass and controller functions as POD Go Edit does. If you go to the Command Center, you can assign commands to the footswitches and see what footswitches have commands programmed to them. The easiest way to see what’s assigned to what in HX Edit is to click on the Bypass/Controller Assign tab. You’ll see a color-coded list of all the assignments in the panel on the lower left part of the screen. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted August 25, 2020 Share Posted August 25, 2020 Right click the block, then Quote Link to comment Share on other sites More sharing options...
