flop54 Posted September 1, 2020 Share Posted September 1, 2020 Hello, I use my helix for recording my bass guitar. I use the 2 path to have 2 mono chanel . The firts one is my clean and fx sound and th second one is for the saturation. I want to separate the output so i send the first path on output 1/2 and the second on 3/4. I use the output 7 to have a dry signal. My problem is that i can hear the bass when I record. I can if i ask to my Software but in that way i have a lantency. Is there an issue to have a direct sound with the helix to record without the latency? If i use the multi parameter it works but i can't have separate output... Sorry for my english i hope you understand me. Quote Link to comment Share on other sites More sharing options...
gunpointmetal Posted September 1, 2020 Share Posted September 1, 2020 Just trying to clarify: You'd like to monitor the DI signal going into the computer on USB 7 along with the Clean/Saturated channels via the Helix outputs while you're tracking? Quote Link to comment Share on other sites More sharing options...
flop54 Posted September 1, 2020 Author Share Posted September 1, 2020 yes i think you got it. Actually i have three track : one for the DI signal (7) one for the clean channel (1/2) and one for saturated (3/4). When i'm recording i hear no sound so i use the monitor in reaper but the latency make it hard for recording. Quote Link to comment Share on other sites More sharing options...
gunpointmetal Posted September 1, 2020 Share Posted September 1, 2020 If you connect your headphones or speakers to the Helix you should be able to monitor at the very least the clean channel while you're recording. I'm not sure if you can monitor the other USB sends from the Helix, but at least that way you'd have one sound that was not delayed by the software. Quote Link to comment Share on other sites More sharing options...
flop54 Posted September 1, 2020 Author Share Posted September 1, 2020 i connect my headphones to the helix but i can't hear no track Quote Link to comment Share on other sites More sharing options...
gunpointmetal Posted September 1, 2020 Share Posted September 1, 2020 8 minutes ago, flop54 said: i connect my headphones to the helix but i can't hear no track You'll have to check your USB routing in Helix. It's possible you've routed audio to USB tracks and bypassed the physical outputs of the Helix. Quote Link to comment Share on other sites More sharing options...
gunpointmetal Posted September 1, 2020 Share Posted September 1, 2020 From the Manual. Quote Link to comment Share on other sites More sharing options...
flop54 Posted September 1, 2020 Author Share Posted September 1, 2020 i think i got it! i have to let the "usb in1/2 destination parameter" on multi and i have to send the first channel on 3/4 and the second on 5/6. Thank you for your help! 1 Quote Link to comment Share on other sites More sharing options...
