Amp Volume Range With The Expression Pedal
pacard
I have my on-board expression pedal (EXP1) set up to adjust the volume of the amp. But I can't figure out how to change the max/min volume settings of the amp from the HD500x pedal. I can do it using the HD500x Edit on my PC. Just stumped as to how i do it when I don't have my PC available.
Anyone know? Thanks in advance!
Simple.
Move the cursor over the amp model,
double click the MOVE button,
with the encoder n.1 select the parameter (in your case VOLUME),
with encoder n.2 select the controller (EXP1),
and select the min and max values with the encoders 3 and 4.
if you want to make permanent the editings save the patch
_______________________________________________________________________________________________________________________________________________________________________
All about POD HD500/X
help and useful tips
