Can you export cab models from HX Stomp and import to PC+?
lavaspin
Hi all, I think the answer is "no" but wanted to make sure. After using the speaker models for the last year, I'm thinking I just want to use a few of the Helix / HX Stomp cab models. I know I could load some IRs but I'm tired of chasing tone and know what I could use from Helix. Thx!
Well... If you're clever, you can use a tool like Logic Pro X's Impulse Response Utility to capture an IR of the HX Stomp cab model you like and put that IR in PowerCab+. But I wouldn't bother. Just use an amp+cab block in HX Stomp to get both with one block.
  • 1 month later...
  • 5 months later...
The Helix Native plug-in truly is the same set of astounding amps, cabs & effects as  NOTE: If you are the registered owner of a Line 6 Helix or HX device, or POD  presets (see “Importing and Exporting Helix Preset Files”) and IRs (see “Importing  HX Stomp. HX Effects. Included. Models*. Full set of v2.90. Helix models.
