Bypass Amp & Cab or not?
blairlockhart
If you are going to a guitar amp best practice would be going from the pod go to the fx return/power amp in of your amp. In pod go you would disable only the cab (either in the patches or by using amp out connection with pre cab/IR global option enabled). If you use amp out jack keep in mind that the volume knob of the pod doesn't work (nor does the global eq, if you set that), because ideally you are supposed use the volume pot of your amp.
Anyway if your amp is set very clean you could try the same but entering in guitar input. But usually that sounds worst. Just give it a try.
Another way is using 4 cable method, if you fancy that. Check also the manual.
