wildgrass Posted September 16, 2020 Share Posted September 16, 2020 First of all, I apologize for not being proficient in English. This is my first time purchasing hxstomp and using it. And before that, the audio interface umc202hd was connected to my computer. But if you connect it to USB to control hxstomp and start cakewalk umc202 is not recognized at all in daw, only hxstomp is recognized. The same goes for turning off the hx stomp-related stuff in the Windows sound settings. What I want to do is control the hx stomp with hx edit, and the hx stomp's sound goes into the audio interface and output to the daw. Thanks for your help and advice. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted September 16, 2020 Share Posted September 16, 2020 1) Install HXEdit v2.92 and follow the directions to update the HXStomp FW. You may have to re-install HXEdit (not the FW) every time Microsoft issues a Windows update in order to re-install the drivers. 2) Install the latest UMC202HD drivers. 3) In Windows Sound Panel you must select a PRIMARY Audio driver. That will be the one that Windows Sounds, including YouTube, Streaming services, etc will use. It does NOT have to be the same one as your DAW uses. 4) In Windows, you can only have one ASIO driver active at a time. In Cakewalk, in order to use an ASIO driver, you must first de-select (un-check) all of the Inputs/Outputs for the currently active driver before the other driver becomes available. Quote Link to comment Share on other sites More sharing options...
