C_berg1980
Pod Go + Powercab 112 Plus recommended setup?
I bought the Pod Go and also purchased the Powercab 112 Plus also. I'm not able to get good tone using the two together and I'm unsure as to what the units settings should be set to in order for both units to preform at their best. I can not find a video or forum topic that provide guidance in the best connection settings when using the Pod Go and the Powercab 112 Plus together.  For example: Do I need to turn the cab sim off on the Pod Go and use the Flat setting in the powercab or the cab simulation on the powercab?  I can't figure out what the best settings are while using these two units together. Any help would be much appreciated.
I've responded you on the other thread you've opened. You actually can do both, set cab sim on the powercab and off on the pod go, or vice versa. I'd go with the second option so you get more flexibility. So check the other thread...
Another hint.  If you have the PowerCab sitting flat on the floor, it will sound like crap, especially on carpet.  Get it up off the ground or at least tilt it back. When I got mine I was frustrated at how bad it sounded initially until I got it off the floor.  Now it sounds great.
