jcarmody Posted September 19, 2020 Share Posted September 19, 2020 Greetings So, I have an Arturia Microfreak, and want to use my Hx Stomp as an effects unit. Unfortunately, I'm unable to get any sound. I've tweaked the gain, the output volume on the synth. Is there something special one needs to do to use as an effects unit for something other than a guitar? (I never have had problems with my guitar.) Thanks much JC Quote Link to comment Share on other sites More sharing options...
rvroberts Posted September 20, 2020 Share Posted September 20, 2020 So how are you connecting it? Are you using the audio out of the synth into the guitar in? Or are you thinking it might connect over USB? - probably not! Use the audio approach - you probably need to set the input level on the stomp to line. Then you go synth to stomp to amp. Should be fine (assuming both devices work and you have a few decent audio cables!!??). Plenty of other people doing it. 1 Quote Link to comment Share on other sites More sharing options...
