ansiwi Posted September 26, 2020 Share Posted September 26, 2020 when i record using FL Studio or Audacity, the recording sound is very low. The only way i manage to make the recording sound ok is by opening POD Farm 2 and selecting the device UX2(ToneDirect) on preferences, but that only makes the monitor sound ok, when i record its low again. I have the last version of Line 5 monkey, POD farm 2 and drivers. I'm using windows 10. Quote Link to comment Share on other sites More sharing options...
Triryche Posted September 28, 2020 Share Posted September 28, 2020 You may be recording only the dry signa. Can you post a sound clip of the low recording? Quote Link to comment Share on other sites More sharing options...
ansiwi Posted September 29, 2020 Author Share Posted September 29, 2020 https://drive.google.com/drive/folders/19ZNMrmdDZFFsFcE7G9zYVRHtA1ousDZx?usp=sharing here's a drive folder with a sample of the recording on a electroacustic guitar pluged into the Pod Studio UX2, and also screenshots of the settings on my POD farm and audacity. Is there any way to record the sound that i get when i open POD Farm? That's the only way i can get it to sound ok, but i don't see a way to record it Quote Link to comment Share on other sites More sharing options...
Triryche Posted September 29, 2020 Share Posted September 29, 2020 I won’t be able to access google docs until later. Audacity does not support ASIO drivers out of the box due to Steinberg licensing. You can compile Audacity to support ASIO (google Audacity ASIO), but the easier option IMHO is try a DAW that supports ASIO out of the box. Reaper is free to try and cheap to buy. With the proper Line6 ASIO drivers you will have 4 sends available to record, 2 Dry and 2 Wet. I typically capture all 4 then add the PF plug-in to the dry track post processing. Quote Link to comment Share on other sites More sharing options...
ansiwi Posted September 30, 2020 Author Share Posted September 30, 2020 i'm trying reaper and the sound is better than audacity, but i'm still pretty sure that is not as loud as i hear it when i use POD Farm. Is there something i should change in the settings? Quote Link to comment Share on other sites More sharing options...
Triryche Posted September 30, 2020 Share Posted September 30, 2020 Download the Line6 ASIO driver and select that in Reaper. In Reaper the last input should be 4 if you want to capture L/R dry and L/R wet (to 2 separate tracks). In the mixer view of PF or the Line6 AudioMIDI control panel you need to configure your sends for wet and/or dry. ASIO4ALL is fairly useless these days expect as a last resort. Quote Link to comment Share on other sites More sharing options...
ansiwi Posted October 1, 2020 Author Share Posted October 1, 2020 Great! it's working now! thanks for the help! Quote Link to comment Share on other sites More sharing options...
Triryche Posted October 1, 2020 Share Posted October 1, 2020 Cool!! Glad you got it sorted. Quote Link to comment Share on other sites More sharing options...
