titchyblackcat 23 Posted September 30, 2020 Hi The power supply says 3A which is quite a heavy load. Does the HX Stomp actually draw 3 amps or is the power supply a higher rating than necessary ? Quote Share this post Link to post Share on other sites
cruisinon2 2,595 Posted September 30, 2020 Don't know... but what I do know is that electronic devices draw the amount of current they need, so as long as the power supply isn't under powered for the unit it's plugged into, then it's a non-issue. Power supplies that come with a given device are often capable of putting out more juice than that device actually requires. Quote Share this post Link to post Share on other sites
titchyblackcat 23 Posted September 30, 2020 OK Thanks. I've just bought my unit sp i'm trying to understand everything. Quote Share this post Link to post Share on other sites
Schmalle 77 Posted September 30, 2020 I've measured about 0.7A while booting and about 1A current draw after that with a patch with looper, amp sim, cab, IR, eq and reverb which (according to this) is about of 75% dsp usage. Quote Share this post Link to post Share on other sites
davi_ssilva 1 Posted September 30, 2020 I talked to James Lebihan from Mission Engineering a few days back and he told me that the HX Stomp may require up to 2A in order to run completely stable, although some people may never have any trouble if they use a 1A power supply, just because they never push their Stomp to its limits. OTOH, I tend to think that the HX Stomp is a "work in progress" kind of gear, and with some future firmware updates its power requirements may increase. So, if we want to play really safe and with a "future proof" mindset, I think we should use a 3A power supply, just like Line 6 did. 1 Quote Share this post Link to post Share on other sites
titchyblackcat 23 Posted October 1, 2020 Great info' many thanks. Quote Share this post Link to post Share on other sites
thesumpter 2 Posted October 1, 2020 These guys measure it for you...nice article. I'm not affiliated btw :) but I might get one! 1 Quote Share this post Link to post Share on other sites
titchyblackcat 23 Posted October 4, 2020 Thanks. Great Info' Quote Share this post Link to post Share on other sites
