POD HD500 as audio interface to record acoustic guitar
Hello!
I want to use my POD HD500 as an audio interface to record my acoustic guitar using the guitar/aux input. I use USB to connect the POD to the computer.
In this case, what would be the most correct way to use it: should I create an empty preset or use it in Bypass (tuner)?
Thank you!
Regards,
Rafael
23 hours ago, fflbrgst said:
The best acoustic guitar sound is going to come from miking the guitar, not plugging it in.  But if you can get the sound you want with a preset, then record that.  Doesn't 'bypass' mute the output??
You have two options. You can use the tuner by listening to the sound bypassed or muted.
