Schivosa Posted October 5, 2020 Share Posted October 5, 2020 I am using the Pod Go for my interface and I am getting popping noises in Reaper. I have increased the buffer size in Reaper to its limit (6000). It helps some but not completely. Is there some setting in the Pod that I can try? Quote Link to comment Share on other sites More sharing options...
cristt Posted October 6, 2020 Share Posted October 6, 2020 Usually that noise happens when your machine can't hold up to the audio signal. Normally modifying the buffer size solves the issue as you correctly did. Did you try also to lower the bit depth? What latency are you getting in reaper (if I remember well you see the value at the top right corner)? Or, might also be that you are clipping the signal, maybe your pod volume is too high? There's a global preference on the pod go to trim the usb signal. Give it a go. Quote Link to comment Share on other sites More sharing options...
