joosee Posted October 8, 2020 Share Posted October 8, 2020 I have a Pod Pro with the following problem, when I turn on the unit, on the two digit numeric display, the leters, "Pod Pro" Appear in sequences one after the other, but it stays in the "o", the last letter of "Pod Pro" name, and the front panel controls do not respond, None of the buttons work, it freezes, other times when i turn it on, the process runs again but this time when display the last leter, the "o", it stay a second and then restarts, the process begins again, stays in a loop, who's been through the same problem and I solved it., please help. Quote Link to comment Share on other sites More sharing options...
daveny5 Posted October 8, 2020 Share Posted October 8, 2020 You may want to try a factory reset. If that works then try to flash the memory from Line6 Monkey. POD/POD 2.0/Bass POD/POD Pro: press and hold the up and down arrow buttons as you power the unit on for ~ 5-7 seconds or until it goes to the preset 1-A Quote Link to comment Share on other sites More sharing options...
