Loud pop when turning off?
boxfurspam
  • 2 months later...
  • 1 year later...
My Pod Go also pops when switched off, regardless of volume setting, and it's loud. it's more of a sharp CRACK! If I have headphones on, it's painful.
So what was the resolution here? Did Line 6 provide any support/fix? What about home remedies, like a capacitor across the power switch?
The remedy to protect your ears is the usual best-practice one: turn off amp/speakers/monitors, or remove headphones, before you turn off any connected equipment. It’s been good practice since electric guitars were invented.
My Pod Go does not do this so there could be a problem with your Pod Go or (more likely) your local power.
If I go into a high gain patch with amp & distortion block with Pod Go Volume dial at 3 O'Clock and turn off PG whilst wearing headphones (which I never do) I can hear a slight 'pop' but nothing loud or alarming.  With clean patches it's almost nothing.  But you should always do as @silverhead said above. Particularly with a real amp and cab you could actually damage a speaker if you don't turn off gear in the right order.
