spanny
Volume Drop in 4CM
I recently upgraded from running an HX Effects to a Rackmount Helix in 4CM with my amp.  Today I noticed there were occasional volume drops only when one of the Helix's effects blocks were engaged.  I do not have a volume block in the chain.  Any thoughts as to what could be causing this?   Thanks!
Ya. There are volume changes with effects blocks. They are modeled on real-world analog effects so they don't always match up. Fortunately there is usually an output volume control that you can use to match the volume to your taste.
The volume drop was happening at random after the effects blocks were engaged.  I think it may have been a DSP issue as I removed 1 block in the chain and the issue went away.
