External Expression Pedal capabilities
boynigel
I'm gonna be carful with this one but I really bet that you do can control more than one parameter at a time, just as you can do that with every switch. Just select the effect and in bypass/control page select the parameter and assign to the exp pedal (with min and max values).
check out this video:
Yes, @cristt is quite correct...external pedals can be assigned multiple parameters and are very similar to on board pedals except these do not appear in the 6 section stomp window. I have 2 momentary switches connected in FS7/FS8 and each can control any combination of parameters that the on board FS1-FS6 can.
