Sign in to follow this
tribal123
Connect Pod HD Desktop to a mixer
I  have  a Pod Hd desktop version and i would like to know how to connect to a normal mixer, can be made through normal cable from Left Output ?
LINE6 POD HD DESKTOP COMPLETO CON ALIMENTATORE E SCATOLA ORIGINALE -  #6670408 - su Mercatino Musicale in Pedaliere Multieffetto per Chitarra
sure... if the mixer has that kind of jack. Most do, but some do not.
but why the left. how about the right?
I assume that left channel is the default, am i wrong?
Since the POD HD is a stereo output device it would be best to connect both the L and R outputs to your mixer. I don’t think that the signal collapses to mono if you only use the L output. If you want to use just the L output make sure you place a mono FX block at the end of the signal chain. That will force a collapse to mono.
