mvk20 Posted November 9, 2020 Share Posted November 9, 2020 Quick question - I’m having a hard time figuring out the behavior of the scribble strip on the EXP1/2 pedal switch when I customize it. Looks like if you try to customize it, it sort of defaults to the name of the wah pedal if that’s what you have attached to EXP1. But then, it seems like it it lit whether the pedal is on or off, and then after stepping on it a few times it seems like it’s dim when the wah is on and lit when the wah is off, which is backwards from what you’d expect. Does anyone know exactly how that aspect works? Quote Link to comment Share on other sites More sharing options...
