adkenyon 0 Posted November 16, 2020 I have a modeler, and really like the look of the 212 plus for running stereo through digital I/O (no Line6 link for me unfortunately, meaning an additional MIDI cable). But I also would like to use it for a full range signal (either a console mix, or from a microphone pre for when I sing backing vocals). Anyone know if you run digital stereo out to the 212+, if you can still run a (mono) analog input to the Aux input in monitor mode? Or does this mean the digital signal will be summed to mono, because you can only have 2 channels total??? Quote Share this post Link to post Share on other sites
HotRats73 0 Posted December 1, 2020 You can feed your 212 with a mono signal without affecting everything else. meaning you can use it as a stereo speaker for your guitar and at the same time as a FRFR monitor for your vocals (or whatever). form the manual: On Powercab, navigate to Global Settings by holding the HOME button and set Input 2 Mode to Monitor. This will use a separate crossover and filters to provide flat-response, full-range audio through the Powercab built-in amplifier and speaker(s) – just like an active PA monito Quote Share this post Link to post Share on other sites
