Pitch shift in HELIX
Dwf2008
Hi, I would like to add a pitch to the Benique preset. I tried adding a Pitch/Synth control near the end of the preset but no matter what I try, I end up getting 2 notes. The original note plucked and the same note an octave lower (which is what I want, just the lower note). Can someone give me some suggestions on how to produce a good preset for Wichita Lineman including the main melody and the guitar solo which is an octave lower? I'd like to do this in a single preset with a snapshot for the bass section. This is my first attempt to create a custom preset so rest assured I am a total beginner.
Thanks
What is the Mix parameter on the Pitch block set to?  If you only want the shifted note, it should be set to 100%. Some blocks have separate Dry and Wet volumes instead of a Mix parameter. In that case your Dry should be set to the lowest possible setting and your Wet volume to 0 dB or whatever volume is appropriate.
