cwelling Posted November 19, 2020 Share Posted November 19, 2020 Anyone else have problems receiving MIDI messages into the USB input from other MIDI over USB pedals? I'm using a DA Electronics iCtrl-R Mini and with the Helix floor, HX Stomp, and PodGO using USB connections, I get nada. All settings for Trasnmitting/receiving MIDI over USB are correct. Any hints/Thoughts? http://www.daelectronics.com/ Quote Link to comment Share on other sites More sharing options...
rd2rk Posted November 20, 2020 Share Posted November 20, 2020 Typically, to use MIDI over USB requires a Host - computer, iOS device or dedicated Host Box. Neither of the videos available on their site using the AXE shows MIDI over USB, they're both using the standard 5-pin DIN connector. Try using that if you don't want to be tethered to a computer. It may be that the USB connection on your device is only intended for updates and programming. There's no manual, so..... Their editor does not include a MIDI Monitor function, so that's a good indicator. I have an FCB1010 connected to one of my computers by USB to use as a controller for my Stomp and VST sims. I use MIDIOX (FREE) to route the signal from the FCB USB connection to the Stomp's USB connection. You can also use MIDIOX to test if I'm right about what I said above about their USB implementation. 1 Quote Link to comment Share on other sites More sharing options...
cwelling Posted November 20, 2020 Author Share Posted November 20, 2020 Thanks, that helps. Quote Link to comment Share on other sites More sharing options...
