copperheadroad Posted November 22, 2020 Share Posted November 22, 2020 Since updating to 3.0 ,(I have my hx stomp hooked up my pc via usb to use hx edit ,but it is going in to a presonus audiobox 22vsl interface . & now as soon as my hx stomp is turned on I loose the any audio on my pc , like a youtube video . i did had this same problem when i first bought the hx stomp & corrected it buy taking the interface out of the equation when installing the software . now having to do this again will not correct the problem . I've tried uninstalling & installing again but with no fix . Quote Link to comment Share on other sites More sharing options...
waymda Posted November 22, 2020 Share Posted November 22, 2020 With no info about your operating system I will guess Windows 10 and suggest you click on the Volume/Speaker icon in the tray to select the default sound device (not the stomp). Other windows versions require you to set that in control panel. Mac - no idea Quote Link to comment Share on other sites More sharing options...
rd2rk Posted November 22, 2020 Share Posted November 22, 2020 Assuming Windows 10, open the Sound Panel and select the computer's sound card as default Playback device. Then take the Headphone out from the computer into a pair of inputs on the VSL, where I assume that you have your speakers connected. Quote Link to comment Share on other sites More sharing options...
copperheadroad Posted November 22, 2020 Author Share Posted November 22, 2020 Running windows 7 , & I don't want to use the stomp as the interface . so as soon as I turn on the stomp my audio from the pc through the stomp . Quote Link to comment Share on other sites More sharing options...
copperheadroad Posted November 23, 2020 Author Share Posted November 23, 2020 Basically I need to turn the built in interface off ,my studio monitors are connected to my presonus interface as well as my pc . & i only have the hx stomp hooked to the pc to us hx edit .after the update as soon as i turn the stomp the audio on my pc is muted . & I did install update with no other audio device connected to the pc as suggested . Quote Link to comment Share on other sites More sharing options...
rd2rk Posted November 23, 2020 Share Posted November 23, 2020 I'm pretty sure W7 worked the same way. Disable the Stomp and enable the Presonus as default. Only difference is you get to Sound Panel from Control Panel. Quote Link to comment Share on other sites More sharing options...
copperheadroad Posted April 17, 2021 Author Share Posted April 17, 2021 Never fails .Same problem again after updating to 3.10 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 17, 2021 Share Posted April 17, 2021 9 minutes ago, copperheadroad said: Never fails .Same problem again after updating to 3.10 Same problem, same solution. It's just the way Windows works. Quote Link to comment Share on other sites More sharing options...
copperheadroad Posted April 17, 2021 Author Share Posted April 17, 2021 With no interface even plugged in & my hx stomp plugged in & turned on , connected to my pc via USB, i loose the sound from my computer . everytime i update i have to deal with this . Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 17, 2021 Share Posted April 17, 2021 There's a guy in Seattle, WA, named Satya Nadella. He works at Microsoft, some kind of big deal. Send him an email and tell him all about it. I'm sure he cares. Quote Link to comment Share on other sites More sharing options...
copperheadroad Posted April 17, 2021 Author Share Posted April 17, 2021 Go it figured out ,go in to the sound /mixer in windows & disable the hx stomp ...this is my reminder when a new update comes out ..lol Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 17, 2021 Share Posted April 17, 2021 Sometimes a Windows update will do it too. If you're using Reaper, sometimes after a Reaper update you need to reinstall HX Edit to get the drivers working again. The mysteries of the digital wonderland! 1 Quote Link to comment Share on other sites More sharing options...
