Yarn5 Posted November 22, 2020 Share Posted November 22, 2020 Hey there, I own a Line 6 HX Effects, for which I installed the update 3.0 yesterday. Lots of super cool features and it's definitely a game changer. However... A feature that I really loved seemed to be now disabled, and I don't know how to get it back. I use the bleat chop tremolo a lot, and before the update, every time I would press the tap tempo button, it'd restart the sequence of the LFO. Super handy feature when you want your tremolo to start on time, on a particular sequence. Anybody has the same problem, or know how to get it back? Basically I just want to use the tap button so the tremolo starts on time, and not randomly in a complex sequence. In advance, thanks and have a great day! Quote Link to comment Share on other sites More sharing options...
Johanivansson Posted December 11, 2020 Share Posted December 11, 2020 I also noticed this! For me it’s a real bummer. I’ve found a way to use it in a sort of side chain compressor way, and I use it all the time. Had to downgrade to 2.91 again. Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted December 12, 2020 Share Posted December 12, 2020 On 11/22/2020 at 6:45 PM, Yarn5 said: Hey there, I own a Line 6 HX Effects, for which I installed the update 3.0 yesterday. Lots of super cool features and it's definitely a game changer. However... A feature that I really loved seemed to be now disabled, and I don't know how to get it back. I use the bleat chop tremolo a lot, and before the update, every time I would press the tap tempo button, it'd restart the sequence of the LFO. Super handy feature when you want your tremolo to start on time, on a particular sequence. Anybody has the same problem, or know how to get it back? Basically I just want to use the tap button so the tremolo starts on time, and not randomly in a complex sequence. In advance, thanks and have a great day! I suppose it could be that something about the operation of that effect has changed with the firmware revision. Barring that the first thing I would look at is 'Tempo Select' and 'Global BPM' parameters under the global settings 'MIDI/Tempo' category. Maybe your globals have changed since the update. 1 Quote Link to comment Share on other sites More sharing options...
Johanivansson Posted December 12, 2020 Share Posted December 12, 2020 18 hours ago, HonestOpinion said: I suppose it could be that something about the operation of that effect has changed with the firmware revision. Barring that the first thing I would look at is 'Tempo Select' and 'Global BPM' parameters under the global settings 'MIDI/Tempo' category. Maybe your globals have changed since the update. Thanks, I will probably upgrade again to try that. Or even better, does it work for you? Are you on 3.01? Quote Link to comment Share on other sites More sharing options...
HonestOpinion Posted December 13, 2020 Share Posted December 13, 2020 4 hours ago, Johanivansson said: Thanks, I will probably upgrade again to try that. Or even better, does it work for you? Are you on 3.01? I am on 3.01 but have not gotten around to testing this. Will post back if I do. Quote Link to comment Share on other sites More sharing options...
