Sign in to follow this
brettmtb
Deleting Presets and Setlists
Is there any way to simply delete unwanted setlist and presets from the Helix using HX Edit or even on the unit itself? I updated to 3.0 and was worried about overwriting old presets with the new ones so now ended up with Two sets of Factory 1 and 2 Setlists - the old and the new!
If you have a completely empty setlist -simply export it then re-import it into the list you want to replace, otherwise read on....
Possibly the quickest way is to first ensure that you have a backup of all your own presets that you want to keep, either as setlists or individual presets Then restart your Helix while holding down footswitches 7&8 which will reset the presets to factory and keep any IRs you have. This should then have only the 2 factory and the template setlist available, the other setlists a cleared out. Then from HX Edit you can export an empty setlist, eg: User 1, then re-import that list to overwrite the setlists you wish to remove ( Factory 1 & 2) then rename the setlist to whatever you want. Doing this means you can essentially create a completely empty Helix and then load whatever you wish, either your own individual setlists or single preset to build your own setlists.
The other thing you could do is find a blank preset, copy and paste it over all the slots that you want to free up. It’s a bit tedious.
Hope this helps/makes sense.
