Why is Poly Sustain Disabled?
robbmelancon
8 hours ago, robbmelancon said:
Can someone explain why/when Poly Sustain effect is disabled?   I am trying to use it in existing presets and the only way I can add it is if I delete almost all of the other blocks in the preset.  Using with Helix floor.
Thanks
Anytime anything is grayed out and unavailable, it's always the same reason... there's not enough available DSP in the path where you're trying to place the effect. Polyphonic effects chew up a great deal of processing power. You'll have to rearrange things, and sacrificing one or more other blocks will probably be necessary if the patch is already busy with a bunch of other stuff.
