mkmona04 Posted November 24, 2020 Share Posted November 24, 2020 I want to play backing tracks from my computer through the Pod Go so i can can jam with them and lsiten with my headphones on. I changed the Global setting so that the fx return/aux is set to always on aux in. But the music is not playing from the laptop? Quote Link to comment Share on other sites More sharing options...
ElectroStrat Posted November 24, 2020 Share Posted November 24, 2020 Have you enabled the FX loop block ? Quote Link to comment Share on other sites More sharing options...
grdGo33 Posted November 24, 2020 Share Posted November 24, 2020 The point of that option is that FX loop doesn't have to be on :) I'd check computer side, you likely don't have any sound from the computer, also, if your PGo is connected via USB, I think you can play music directly to PGO through USB, that would probably be a better setup. Software like 'Audio Switcher' also allows you to quickly switch sound between different devices. Quote Link to comment Share on other sites More sharing options...
mkmona04 Posted November 24, 2020 Author Share Posted November 24, 2020 4 hours ago, grdGo33 said: The point of that option is that FX loop doesn't have to be on :) I'd check computer side, you likely don't have any sound from the computer, also, if your PGo is connected via USB, I think you can play music directly to PGO through USB, that would probably be a better setup. Software like 'Audio Switcher' also allows you to quickly switch sound between different devices. i am conencted via usb to the cpmtpeiur to use the pod go edit software. how would i play music through the usb too? Quote Link to comment Share on other sites More sharing options...
grdGo33 Posted November 24, 2020 Share Posted November 24, 2020 https://www.myofficetricks.com/how-to-change-default-output-device-on-windows-10/ something like that. Or, so say you're using Winamp or whatever, you choose pod go as your output device in your software's settings. and like I said; Quote Software like 'Audio Switcher' also allows you to quickly switch sound between different devices. https://www.audioswit.ch/er https://www.audioswit.ch/download/latest Quote Link to comment Share on other sites More sharing options...
mkmona04 Posted November 25, 2020 Author Share Posted November 25, 2020 ok - this is weird - if i port the sound out from the macbook to the pod go through the usb, i can hear it through the headphones plugged into the pod go, but not the amp if the amp is plugged into the amp out line. if i port the sound from the macbook through the headphone wire to the podgo aux in line, no sound through amp or headphones? Quote Link to comment Share on other sites More sharing options...
jcnesbitt Posted November 26, 2020 Share Posted November 26, 2020 I just put one of these wireless receivers into the aux input and connect wirelessly to stream audio. Makes it super simple. You will of course need a 1/4” adapter. Quote Link to comment Share on other sites More sharing options...
cbaten Posted December 29, 2020 Share Posted December 29, 2020 Hi all, The aux in feature is a great feature. It is the 2nd means of running a background track through the Pod Go. The other option being the USB 1/2 audio in. But unlike the USB in the Aux in lacks a level adjustment option. Also it seems that in general the aux in seems to come in at a relatively low level, cpompared to the level of all the guitar patches (several of the comments here and from own experience). Even trying to fool the system by changing the return level from 'line' to 'instrument' was not sufficient. The only way dealing with this now is to adjust the level of all 256 patches individually. This can not be the intention of this feature. So I have suggested this extra feature in 'ideascale' for the next firmware update. Please vote if you agree! What is needed is a global level adjustment for either model signal chain output or for the 'aux in'. If possible the latter seems the better choice as for signal to noise ratio. I oculd be done in a similar way in the general settings as is done for the USB audio in. If you agree please vote as well. Cheers, Chris Quote Link to comment Share on other sites More sharing options...
dzobels Posted June 16, 2023 Share Posted June 16, 2023 Well, three years have passed and the Pod Go still can't do what 4 prior generations of Pods could. In all earlier models, and I've owned them all, the main volume knobs adjusted the final guitar out and left the aux in at whatever volume was carried to it. This made balancing guitar to backing track simple. If a patch was too hot, just turn down the volume and the backing track stays the same. Viola! Simple. Why in the hell was this changed in the Pod Go. I performed solo easily without crowding my PA mixer. Now, I have to use every mixer input just to keep guitar and music balanced. Okay, that's enough griping from me. All my searching has shown that this issue is not something Line 6 gives a crap about. Quote Link to comment Share on other sites More sharing options...
