miami_vice
Can FS7/8 control preset up and down?
I read somewhere on line that this was possible, but I'm starting to think its not.
I have a two button footswitch without LEDs that I intended to use for up/down, and then do 6 button stomp mode on screen.  I'm in the global settings but none of these look to me to allow this - am I out of luck?
Unfortunately yes, you can't currently use F7/F8 to control patch up/down. It's something I added as a 'want' to the Line 6 'Idea Scale' a while back.  It's such an obvious use for F7/F8, I'm surprised Line 6 didn't add it as an option.
that was my thinking.  i can still do what i want now, but it would be easier with the screen showing 6 stomps AND the preset I'm on.  that takes the guesswork out of what you assigned to 7/8.
is there a way for me upvote your suggestion?
By all means
You can sign-up here: https://line6.ideascale.com/a/ideas/top and then search 'Pod Go' to see all Pod Go suggestions, and vote for what you like.
Whilst you're there, please vote for these too - also, there are duplicates as different folk post with the same idea so please vote for any you see - all the following relate to footswitch operation & screen visibility/naming:
https://line6.ideascale.com/a/dtd/Pod-Go-FS7-FS8-as-patch-up-down-footswitches/992128-23508
https://line6.ideascale.com/a/dtd/Pod-Go-Expanding-screen-information-visibility-re-FS7-FS8/994299-23508
https://line6.ideascale.com/a/dtd/POD-Go-—-allow-Snapshot-renaming/975781-23508
https://line6.ideascale.com/a/dtd/Name-changes-for-footswitches-in-Pod-Go/986002-23508
https://line6.ideascale.com/a/dtd/POD-Go-Snapshot/995400-23508
https://line6.ideascale.com/a/dtd/Pod-Go-View-Assignment-to-external-footswitches/990206-23508
https://line6.ideascale.com/a/dtd/POD-Go-Multiple-Parameter-Label-Customization/987923-23508
https://line6.ideascale.com/a/dtd/Pod-Go-great-but-needs-important-tweak-for-gigging-players/986266-23508
