merdenoms74 Posted November 25, 2020 Share Posted November 25, 2020 I have something a bit weird happening where a footswitch that I have set to recall a snapshot takes two presses to switch. At first I thought the switch had gone bad but then I realised it's only happening on one particular patch and it consistently takes two presses to activate it. Is there a setting somewhere that I need to change? I can't see anything I've done differently in Command Center. I've attached the patch if anyone wants to check it out. It's footswitch 9 (labelled 'CHORUS'). ADORE YOU.hlx Quote Link to comment Share on other sites More sharing options...
merdenoms74 Posted November 25, 2020 Author Share Posted November 25, 2020 Okay, so if I change the 'release' setting for that switch to Snapshot 3 it works the way it should. Oddly, it switches on the first press, rather than the release as you would expect. If I set it back to 'none' the problem comes back. Very odd. Quote Link to comment Share on other sites More sharing options...
