Dyyk Posted November 27, 2020 Share Posted November 27, 2020 I have my Helix rack hooked up to my computer via USB so I can use HX edit, but also via the analog outputs into my soundcard for recording in Cubase. When I play a song Cubase uses the Helix as playback device for my midi-tracks, and since I have the analog outputs going into cubase it creates a feedback loop. Is there any way to turn off all midi-functions in the Helix? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted November 27, 2020 Share Posted November 27, 2020 Need more info. Audio feedback? MIDI feedback? The analog outs have nothing to do with MIDI. What's actually happening? What soundcard are you using? Quote Link to comment Share on other sites More sharing options...
DunedinDragon Posted November 27, 2020 Share Posted November 27, 2020 If you're Helix is hooked up to your PC via USB you can do everything from there, given that you have some speakers attached to the Helix. If you have the Helix and a soundcard attached to your PC, your PC will only use one or the other for input and output which is determined by what is set up in your sound settings when you select that by right clicking on the little speaker icon at the lower right hand of your screen. I'm not sure where MIDI comes into play here at all. If you selected the Helix for sound input as described above it's going to play the audio signal from Cubase, not the MIDI. Quote Link to comment Share on other sites More sharing options...
Dyyk Posted November 30, 2020 Author Share Posted November 30, 2020 In cubase i have my in/out set to my RME ASIO driver. If I have my helix turned off everything works as is should but if I turn it on it "hijacks" the output from miditracks that are set to wavetable (not tracks that are set to samlers/instruments). So if i turn the volume knob down om my helix it also lowers the volume of those midi tracks. I have checked the midi I/O in my cubase device setup and everything is set to RME. The feedback like a doubled slightly delayed playback and a significant volume boost which feeds in to my soundcards analog input. Quote Link to comment Share on other sites More sharing options...
DunedinDragon Posted November 30, 2020 Share Posted November 30, 2020 3 hours ago, Dyyk said: In cubase i have my in/out set to my RME ASIO driver. If I have my helix turned off everything works as is should but if I turn it on it "hijacks" the output from miditracks that are set to wavetable (not tracks that are set to samlers/instruments). So if i turn the volume knob down om my helix it also lowers the volume of those midi tracks. I have checked the midi I/O in my cubase device setup and everything is set to RME. The feedback like a doubled slightly delayed playback and a significant volume boost which feeds in to my soundcards analog input. Assuming we're talking about a Windows machine, the Helix isn't doing anything other than announcing it's USB presence as a sound device and Windows is selecting it for a default output is my guess. Regardless of what Cubase is doing, the active sound device is ultimately controlled by the operating system. You should be able to select and control the active/default output device by right clicking on the speaker icon on the lower right hand corner of your PC screen. Quote Link to comment Share on other sites More sharing options...
