JackRabbit160 2 Posted November 27, 2020 Hi all, This is more of a heads up, as I have a resolution (of sorts) to my issue. Like many, I made the jump recently from F/W 2.92 to 3.00. I'm not normally an early adopter but recent firmware updates had gone well and so I deviced to have a leap of faith. The update itself went without hitch, but I soon ran into issues whilst using a 1SW Looper (the problem may also relate to the 6SW, etc., but I've not tested). As a relative newbie to playing guitar, my setup is incredibly simple, so nothing I'm doing is likely to be taxing the HX Effects unit too heavily. In fact, in this paticular case my setup simply included a Bass Octaver, Analog Flanger, Minotaur, Plate Reverb, LA Studio Compressor and a single switch looper (all on a single path). My problem is that recording a 4 bar loop causes the HX effects to hang. I'm unable to end the loop and all switches and buttons cease to function; my only option being to power off the device. I thought it may be an issue carried over from previous settings, so I performed a factory reset. Initially, I restored (only) my Presets, but as the problem persisted, I conducted a second factory reset and setup the pedals fresh. No difference, the unit still hangs. I've managed to resolve my issue by reverting to 2.92 (which works perfectly), but this isn't ideal. I can't think what else to try at this stage and/or I'm not sure what additional information is needed to help troubleshoot. Anyway, as I said, this is more of a heads up (for others who may be suffering the same issue). If anyone has any ideas, I'm all ears. Also, I'm happy to provide additional information and/or conduct tests if it will prove beneficial. Regards Jack. 1 Quote Share this post Link to post Share on other sites
simonjhopkins 0 Posted December 7, 2020 I have just experienced exactly the same thing.. Just moved house, so doing a late upgrade.. My HX effects unit does the same thing.. (I have in the past had issues with the unit - comms to PC still dodgy), but last couple of updates was building back my confidence.. Until this.. At least it may be a bug that needs fixing.. I had used all 9 blocks, ( patch made up from new) only using about 3 blocks actively.. When using 1Sw looper - nothing happened.. No LEDs etc. Then about 2mins later my guitar noise after pushing button comes through. Like you, I have to cycle power to reset.. I will try raising a ticket with L6 support.. Simon Quote Share this post Link to post Share on other sites
HonestOpinion 922 Posted December 7, 2020 On 11/27/2020 at 5:26 AM, JackRabbit160 said: Hi all, This is more of a heads up, as I have a resolution (of sorts) to my issue. Like many, I made the jump recently from F/W 2.92 to 3.00. I'm not normally an early adopter but recent firmware updates had gone well and so I deviced to have a leap of faith. The update itself went without hitch, but I soon ran into issues whilst using a 1SW Looper (the problem may also relate to the 6SW, etc., but I've not tested). As a relative newbie to playing guitar, my setup is incredibly simple, so nothing I'm doing is likely to be taxing the HX Effects unit too heavily. In fact, in this paticular case my setup simply included a Bass Octaver, Analog Flanger, Minotaur, Plate Reverb, LA Studio Compressor and a single switch looper (all on a single path). My problem is that recording a 4 bar loop causes the HX effects to hang. I'm unable to end the loop and all switches and buttons cease to function; my only option being to power off the device. I thought it may be an issue carried over from previous settings, so I performed a factory reset. Initially, I restored (only) my Presets, but as the problem persisted, I conducted a second factory reset and setup the pedals fresh. No difference, the unit still hangs. I've managed to resolve my issue by reverting to 2.92 (which works perfectly), but this isn't ideal. I can't think what else to try at this stage and/or I'm not sure what additional information is needed to help troubleshoot. Anyway, as I said, this is more of a heads up (for others who may be suffering the same issue). If anyone has any ideas, I'm all ears. Also, I'm happy to provide additional information and/or conduct tests if it will prove beneficial. Regards Jack. 8 hours ago, simonjhopkins said: I have just experienced exactly the same thing.. Just moved house, so doing a late upgrade.. My HX effects unit does the same thing.. (I have in the past had issues with the unit - comms to PC still dodgy), but last couple of updates was building back my confidence.. Until this.. At least it may be a bug that needs fixing.. I had used all 9 blocks, ( patch made up from new) only using about 3 blocks actively.. When using 1Sw looper - nothing happened.. No LEDs etc. Then about 2mins later my guitar noise after pushing button comes through. Like you, I have to cycle power to reset.. I will try raising a ticket with L6 support.. Simon The first thing I would do is update to the latest 3.01.0 firmware. You will still be using HX Edit 3.0 as HX Edit 3.01.0 does not exist. There were some non-specific bugfixes in this quickfix firmware release. Maybe they will resolve your issue. 1 Quote Share this post Link to post Share on other sites
Marmotduke 1 Posted December 29, 2020 3.01 does not fix it. I have the exact same issue with the 1sw looper on the HX Effects running 3.01 1 Quote Share this post Link to post Share on other sites
Parrot112 1 Posted December 30, 2020 1st post here so hello everyone. I also have HX Effects 3.01 and had exactly the same problem with the 1 switch looper. Note I've only used it twice, and had the problem both times - I didn't do any diagnostic work (using simpler patches etc) as I'm unlikely to use it anyway. The 6 switch appears to work perfectly though. 1 Quote Share this post Link to post Share on other sites
simonjhopkins 0 Posted December 30, 2020 Yeah, same with me.. I was already updated to the latest versions on everything.. Still having same problem.. I opened a support ticket and am going to keep asking for L6 updates.. My ‘fix’ is that I was lucky not to have sold my ditto looper.. I don’t want to downgrade. (I wonder if Helix and LT / stomp are similarly affected..) Quote Share this post Link to post Share on other sites
scottlasek 2 Posted January 14 Currently running 3.01.0 HX FX I rarely ever use the looper. When I do it's just to test out effects in the chain after the 1 Switch looper. I tried it today and it locks up the whole device. I can still play but cant change anything with any button/knob. A reboot brings it up again but any exsisting patch, or new patch I add the 1slooper to does this. It worked fine on whatever was before 3.0 I did not factory reset as the looper isn't used by me in a band setting. I only use it for help with adjustments to my tone. 1 Quote Share this post Link to post Share on other sites
JackRabbit160 2 Posted January 15 All, Please note, Line 6 released an update (3.02) yesterday which specifically targets this issue. I've not yet tried it, but will do so in the coming hours. Regards Jack. 1 Quote Share this post Link to post Share on other sites
simonjhopkins 0 Posted Saturday at 03:04 PM I did a quick update and looks like problem is sorted.. Looks like Line 6 did the release for this specific issue, so that’s good.. All the best. Quote Share this post Link to post Share on other sites
scottlasek 2 Posted Saturday at 03:53 PM After 3.02.0 update 1 Switch Looper working as it should confirmed 1 Quote Share this post Link to post Share on other sites
Ed_Saxman 84 Posted Saturday at 05:57 PM Updated to 3.02.0, all good. 1 Quote Share this post Link to post Share on other sites
