Nylander88 Posted November 29, 2020 Share Posted November 29, 2020 I wanted to make a list of power supplies that can work with the Stomp, most of these come from online and YouTube by seeing other guitarists (And bassists!) and how they power them. Even though they seem to work with Stomp, Line 6 has Clearly said in their HX Stomp FAQ that they advise to use the provided power supply. To make these power supplies work, you'll need some extra accessories. You'll need a current doubler, (NOT A VOLTAGE DOUBLER!) and a centre negative 2.5mm adapter (Center for you yanks!). The HX Stomp has a power draw of about 800-900 mA, most power supplies will have 9v 500 mA or higher, these are the outputs you are looking for on a power supply. Power Supplies like the Cioks dc7 will have 9v 660 mA, this will not hurt the stomp. So here are the Power Supplies that should work. Voodoo Lab Pedal Power X4 Isolated Power Supply https://www.long-mcquade.com/114125/Guitars/Cables---Power-Supplies/Voodoo-Lab/Pedal-Power-X4-with-Adapter.htm Voodoo Lab Pedal Power X8 Compact Isolated Pedal Board Power Supply https://www.long-mcquade.com/172388/Guitars/Cables---Power-Supplies/Voodoo-Lab/Pedal-Power-X8-Compact-Isolated-Pedal-Board-Power-Supply.htm Voodoo Lab High Current Power Supply https://www.long-mcquade.com/70394/Guitars/Cables---Power-Supplies/Voodoo-Lab/High-Current-Power-Supply.htm Strymon Ojai High Current DC Power Supply https://www.long-mcquade.com/73948/Guitars/Cables---Power-Supplies/Strymon/Ojai-High-Current-DC-Power-Supply.htm Strymon Zuma Power Supply https://www.long-mcquade.com/78116/Guitars/Cables---Power-Supplies/Strymon/Zuma-Power-Supply.htm Truetone CS12 Pure Isolated Power Brick https://www.long-mcquade.com/61870/Guitars/Cables---Power-Supplies/Truetone/CS12-Pure-Isolated-Power-Brick.htm Truetone CS6 Pure Isolated Low-Profile Power Supply https://www.long-mcquade.com/95105/Guitars/Cables---Power-Supplies/Truetone/CS6-Pure-Isolated-Low-Profile-Power-Supply.htm Cioks DC7 https://cioks.com/products/dc7/ CIOKS DC7 with this current doubler and this adapter cable to get to the 2.5mm plug for my HXFX. Both are made by CIOKS. For the Cables Strymon Power Supply and Line 6 Pedal Current Doubler Cable https://www.logsdonaudio.com/cables/strymon-power-supply-and-line-6-pedal-current-doubler-cable Voodoo Lab Current Doubler Adapter https://www.long-mcquade.com/15778/Guitars/Cables_Power_Supplies/Voodoo_Lab/Current_Doubler_Adapter.htm 2.1mm to 2.5mm DC Crossover Cable https://missionengineering.com/shop-2/products/cables/9v-2-5mm-dc-crossover-cable/ Amazon Cable https://www.amazon.com/gp/product/B016BJGZ2U/ref=crt_ewc_img_huc_1?ie=UTF8&psc=1&smid=A3TUR5JBYCEPNE CIOKS DC7 with this current doubler and this adapter cable to get to the 2.5mm plug for my HXFX. Both are made by CIOKS. Wall Plugs Upbright LH-12300 https://www.amazon.com/Line-NSA27EU-090300-HD500X-Multi-Effects/dp/B0154WFJDG/ref=sr_1_1?dchild=1&keywords=Upbright+Line+6+Adapter&qid=1614386173&sr=8-1 *If your wondering why everything is so expensive, some of it is in It's in CAD* @Digital_Igloo I hope what I've said is correct! If not please let me know! Quote Link to comment Share on other sites More sharing options...
benriddell Posted November 29, 2020 Share Posted November 29, 2020 Unit GigRig modular power supply kit: https://shop.thegigrig.com/power-base-pack-1/ Addtional cable 2.1mm to 2.5mm (not the "Line 6" option as that one is centre positive): https://shop.thegigrig.com/cable-adapters/ 1 Quote Link to comment Share on other sites More sharing options...
johannkleen Posted November 29, 2020 Share Posted November 29, 2020 There are 2.1 to 2.5mm cables, would one of those work from one output from the CS6 or CS12??? Quote Link to comment Share on other sites More sharing options...
Nylander88 Posted November 30, 2020 Author Share Posted November 30, 2020 3 hours ago, johannkleen said: There are 2.1 to 2.5mm cables, would one of those work from one output from the CS6 or CS12??? The 2.1 side would be connected to the CURRENT doubler the goes into two 9v 500 mA, the HX Stomp takes the Center Negative side. Quote Link to comment Share on other sites More sharing options...
Gainzilla Posted February 26, 2021 Share Posted February 26, 2021 This cable from Amazon works as well: https://www.amazon.com/gp/product/B016BJGZ2U/ref=crt_ewc_img_huc_1?ie=UTF8&psc=1&smid=A3TUR5JBYCEPNE 1 Quote Link to comment Share on other sites More sharing options...
soundog Posted February 27, 2021 Share Posted February 27, 2021 I'm using an Upbright LH-12300 (on Amazon here). It works without any problems.... Quote Link to comment Share on other sites More sharing options...
loonsailor Posted February 27, 2021 Share Posted February 27, 2021 I'm using the CIOKS DC7 with this current doubler and this adapter cable to get to the 2.5mm plug for my HXFX. Both are made by CIOKS. Quote Link to comment Share on other sites More sharing options...
ColonelForbin Posted May 4, 2021 Share Posted May 4, 2021 Has anyone tested this yet? https://www.sweetwater.com/store/detail/PPHX--voodoo-lab-hx-current-doubler-cable-18-inch-dual-2.1mm-to-2.5mm-straight-barrel-power-cable Conveniently Power Your HX Device with Voodoo Lab The Voodoo Lab HX Current Doubler Cable makes it easier than ever to power your Line 6 HX Effects or HX Stomp device. Using a single cable constructed of two 2.1mm plugs and one 2.5mm plug Quote Link to comment Share on other sites More sharing options...
haasamps Posted May 4, 2021 Share Posted May 4, 2021 5 hours ago, ColonelForbin said: Has anyone tested this yet? https://www.sweetwater.com/store/detail/PPHX--voodoo-lab-hx-current-doubler-cable-18-inch-dual-2.1mm-to-2.5mm-straight-barrel-power-cable Conveniently Power Your HX Device with Voodoo Lab The Voodoo Lab HX Current Doubler Cable makes it easier than ever to power your Line 6 HX Effects or HX Stomp device. Using a single cable constructed of two 2.1mm plugs and one 2.5mm plug I have one, the cable works fine, but using it with the two 450ma outputs of my MXR ISO-Brick isn’t enough to power my HX Stomp. Powers up fine, but the goes haywire when I change presets. Quote Link to comment Share on other sites More sharing options...
kylebarnhart Posted May 6, 2021 Share Posted May 6, 2021 My Truetone CS7 just crapped out on me. So I decided to try my $40 Amazon Donner DP-2 on my HX stomp. To my surprise, using the adapter cables from my Truetone I was able to power it on using the 500ma 9v jack on the supply. If I used the lower milliamps outputs it would power on but not get past the firmware screen. But the 500 worked fine. It currently powering my HX Stomp, an EQD Hoof, JHS Morning Glory, Strymon El Capistan, Walrus Audio Slö Way Huge Saucy Box and a Caroline Somersault. So yeah.... $40 or so off Amazon and a few adapter cables and youre all set Quote Link to comment Share on other sites More sharing options...
joey_morton Posted June 30, 2021 Share Posted June 30, 2021 Does anyone know if the fender engine room level 8 would be compatible to power the hx stomp and the hx effects together (im assuming it didnt exist at the time this post was made). I feel like it could with a couple of current doubler cables but could do with finding out before I go and drop the cash. Quote Link to comment Share on other sites More sharing options...
Joepeggio Posted July 5, 2021 Share Posted July 5, 2021 I use this. I haven't tried my CS7 yet, other pedals using it. https://www.ebay.com/itm/153289303247 Quote Link to comment Share on other sites More sharing options...
RexVaj Posted July 11, 2021 Share Posted July 11, 2021 I am using a power supply by Vitoos ( called ISO 8). It has 9,12 , and 18 volt (switchable) and 1000mA(x2) and has separate isolated sections for the 9v and heavy draw outlets. Using it for about a year now with no problems. it's under my board or i'd put up a pic. Cheap as chips, too! Quote Link to comment Share on other sites More sharing options...
outpourworship Posted August 2, 2021 Share Posted August 2, 2021 On 7/4/2021 at 10:13 PM, Joepeggio said: I use this. I haven't tried my CS7 yet, other pedals using it. https://www.ebay.com/itm/153289303247 I just got the Truetone CS7 and per another post I’m using one power cable to the red adapter to the green adapter. I had no problem with it so far. I’m keeping the Line 6 cord with my gear as backup. Quote Link to comment Share on other sites More sharing options...
wslymsgrv Posted November 3, 2021 Share Posted November 3, 2021 Can you power the HX Stomp with a CIOKS Hi5 MOD? I tried using the green 2.5mm cable and it won't power on. Is there a different voltage setting it needs? It's supposed to be putting out 9v (660mA), isn't that sufficient for the HD Stomp? Trying to avoid having another power cable coming out of my pedalboard for the HX Stomp's brick. Quote Link to comment Share on other sites More sharing options...
Joepeggio Posted November 4, 2021 Share Posted November 4, 2021 12 hours ago, wslymsgrv said: Can you power the HX Stomp with a CIOKS Hi5 MOD? I tried using the green 2.5mm cable and it won't power on. Is there a different voltage setting it needs? It's supposed to be putting out 9v (660mA), isn't that sufficient for the HD Stomp? Trying to avoid having another power cable coming out of my pedalboard for the HX Stomp's brick. I think it needs close to 1000ma to operate as I've learned from others. 1 Quote Link to comment Share on other sites More sharing options...
PierM Posted November 4, 2021 Share Posted November 4, 2021 20 hours ago, wslymsgrv said: Can you power the HX Stomp with a CIOKS Hi5 MOD? I tried using the green 2.5mm cable and it won't power on. Is there a different voltage setting it needs? It's supposed to be putting out 9v (660mA), isn't that sufficient for the HD Stomp? Trying to avoid having another power cable coming out of my pedalboard for the HX Stomp's brick. Nope, 660mA isn't enough for the HX Stomp. With some PS even with 1000 you could be on the edge. You could try with a current doubler with CIOKS rca plugs (NOT A VOLTAGE DOUBLER!), using two output from the Cioks to obtain 9V@660*2mA (9V@1320mA). https://www.logsdonaudio.com/cables/for-cioks-dc7-power-supply-and-line6-pedals-current-doubler-cable 1 Quote Link to comment Share on other sites More sharing options...
Enri- Posted November 5, 2021 Share Posted November 5, 2021 I keep reading here and there that the HX Stomp draws about 1000 mA, and of many reporting they’re successfully powering it, even along with other pedals, with 3rd party power supplies which are rated for less than what specified by Line6. To my knowledge of electronics, which is probably not enough to prove me right, I suspect that a unit which is, SIMULTANEOUSLY, sending the processed guitar signal, in Stereo, through the Main outs and through the effect loops Sends, managing MIDI traffic, communicating with the DAW through USB, and with the processor(s) working close to its (theirs) maximum capacity (i.e. reaching max DSP), would draw MORE current, still maybe not (or maybe yes?) near to the 3000 mA value specified by Line6. What I am trying to say is that everything seems to work fine, only because the HXS is usually not exploited to the maximum of its potential. So you are doing fine with your 3rd party power supply rated at e.g. 1700mA, powering your HXS and a handful of other devices, which you calculated to be, say, 1400mA total; then you start using more functions in the HXS, and your power supply faults. Now, admittedly, you won’t be using everything in your board simultaneously, so the probability that this would happen is not that high, but maybe something worth considering ? Quote Link to comment Share on other sites More sharing options...
kaleidoskope Posted November 19, 2021 Share Posted November 19, 2021 Is there a power supply that has 9v 1A outlets? I'm thinking just to be in the safe side and feed at least 2A to HX? Quote Link to comment Share on other sites More sharing options...
hoellinger666 Posted December 5, 2021 Share Posted December 5, 2021 I was able to fire up the HX Stomp with one single output on the Cioks DC7 … Seems to work seamlessly, with no issues! Quote Link to comment Share on other sites More sharing options...
HD600 Posted December 5, 2021 Share Posted December 5, 2021 My Stomp work with this Power Supply: https://www.thomann.de/de/harley_benton_powerplant_iso_12_pro.htm With this I use this current doubler: https://www.thomann.de/de/voodoo_lab_current_doubler_adapter_ppap.htm with an angled Plug 5,5 mm/2,5 male to 5,5 mm/2,1 female. I use all Outputs with pedals, also powering this power amp pedal: https://www.thomann.de/de/electro_harmonix_5mm_power_amp.htm Everything works fine but I only use this at home and not on stage. Quote Link to comment Share on other sites More sharing options...
mattzz Posted December 26, 2021 Share Posted December 26, 2021 I'm using the smallest of Thomann's power plants with my HX Stomp: https://harleybenton.com/product/powerplant-iso-1-pro/ However, instead of using the current doubler cable I opened the device and wired three outputs in parallel in order to give the LM317 some thermal headroom. It's a 10 minute job if you can tell where the hot end of your soldering iron is. (As the LEDs are switched on only if a barrel plug is inserted the other two LEDs of the triple-port will stay off even though the ports are being used.) Quote Link to comment Share on other sites More sharing options...
PierM Posted December 26, 2021 Share Posted December 26, 2021 Doesn't matter if you wire on the PCB, or bridging parallel at the output with the doubler. Same current draw is still being distributed between those voltage regulators@channel, in both conditions, so the heat management it's the same (basic joule's equation). Then, going picky, if you take into account those short and thick insulated wires you used to bridge directly on the PCB, this is probably holding more heat inside the unit (I^2)*r*t , than using a longer wire on the outside (through the current doubler). Anyway, it will work just fine and for sure looking better. Quote Link to comment Share on other sites More sharing options...
mattzz Posted December 26, 2021 Share Posted December 26, 2021 Correct. However, my point was that I was using three ports instead of two (what most of the current doubler cables are doing) to give more thermal headroom to each of the regulators (~300mA instead of ~450mA per LM317 if you assume 900mA current draw from the Helix). Of course the overall power dissipation will be the same. The decision to do the wiring internally was more based on aesthetics and practicality. 1 Quote Link to comment Share on other sites More sharing options...
gitarzysta Posted December 29, 2021 Share Posted December 29, 2021 Another one that works Rockboard Power Ace 1700mA https://www.rockboard.de/en/power-supply/rockboard-power-ace-set-9v-dc-17a-power-adapter-accessory-cables-rbo-power-ace-set Its plug seems to work for both 2.1 and 2.5mm devices therefore you do not even need a 2.1mm to 2.5mm adapter. Comments: it comes in two packages: just the adapter and with a set of cables. If you buy the set please note the included green adapter not only changes pin size from 2.1 to 2.5mm but also inverts POLARITY! You will need to use the included red cable to invert the polarity again, back to center negative. But as I said the original adapter seems to work ok with hx and pod go without any pin size adapters. Quote Link to comment Share on other sites More sharing options...
shubox82 Posted January 8 Share Posted January 8 On 5/5/2021 at 9:12 PM, kylebarnhart said: My Truetone CS7 just crapped out on me. So I decided to try my $40 Amazon Donner DP-2 on my HX stomp. To my surprise, using the adapter cables from my Truetone I was able to power it on using the 500ma 9v jack on the supply. If I used the lower milliamps outputs it would power on but not get past the firmware screen. But the 500 worked fine. It currently powering my HX Stomp, an EQD Hoof, JHS Morning Glory, Strymon El Capistan, Walrus Audio Slö Way Huge Saucy Box and a Caroline Somersault. So yeah.... $40 or so off Amazon and a few adapter cables and youre all set Hey there, just curious, did you use only 1 9v 500ma jack? Or two of them with a current doubler cord? For the hx stomp? I’m seriously considering The donner dp-2 like you are… and hope it’s still working lol Quote Link to comment Share on other sites More sharing options...
gitarzysta Posted February 15 Share Posted February 15 Power supply - Verifone 9V 4A I found a good, replacement, desktop type (wall/plug power supplies are EVIL ;) ) power supply, part number Verifone DSA-42D-09. I picked mine for 10$ equivalent. Very quiet. Spec: direct replacement 9V center negative 2.5mm tip 4A max Try also "zx spectrum power adapter" - apparently this Verfione was used as ZX Spectrum adapter replacement, too ;) I hope you'll find it useful. Cheers Quote Link to comment Share on other sites More sharing options...
rabbuhl Posted June 3 Share Posted June 3 I got the EU version of the MyVolts HX Stomp adapter. It comes with a small tip which reverses the polarity. https://myvolts.de/product/41869/9V_Line-6_Effektpedal_HX-Stomp_Netzteil_Ladegerat Here is the US version. https://myvolts.com/product/41459/Line-6_Effects-pedal_HX-Stomp_power_supply_adapter_charger Quote Link to comment Share on other sites More sharing options...
taylorbrierley Posted June 12 Share Posted June 12 I am using this power supply https://harleybenton.com/product/powerplant-iso-1-pro/ and this adapter https://www.guitarguitar.co.uk/product/210217366881025--voodoo-lab-hx-current-doubler-cable?gclid=CjwKCAjwnZaVBhA6EiwAVVyv9ACkPGtjWLOQ7dfJRSDOaRPZVA09BJP1VjjHLP2shtGp8qk8gDwUtRoCVcgQAvD_BwE, and like stated above it goes haywire after i switch presets (very loud static noise) but everything else if fine. Why is this as the hx is getting 9v and 1000ma ? Quote Link to comment Share on other sites More sharing options...
