peterschut63 Posted November 29, 2020 Share Posted November 29, 2020 Hi Forum, did anybody used a tube pre in front of Helix. I have a Mesa Boogie Studio Pre and would like to use it as the first stage of a setup. Make a preset with just some delay, maybe a compressor and use an IR cabinet. should I use Aux in, or a loop input. does anybody know the maximum input levels to these inputs? thanks, Peter Quote Link to comment Share on other sites More sharing options...
tmingle Posted November 30, 2020 Share Posted November 30, 2020 I have used my DSL40C in 4CM & split the signal to my DAW with impulses. The 40C's loop is instrument level, so I set the Helix loop to -10db. I would use the Aux in. Quote Link to comment Share on other sites More sharing options...
peterschut63 Posted November 30, 2020 Author Share Posted November 30, 2020 Okay, but that looks like the other way around right, isn't the DSL40C a combo? So the helix sits in an effects loop. That should indeed work fine, and something I tried before with My Mark V Head. Now I want to use the MB Studio Pre as the first stage, so the guitar only sees the tube amp, and will be responsible for a large part of the clean and overdriven sounds. The output of the Helix will go to my monitors, and I could record it in cubase. But indeed use the Aux in (kind of like an active pick-up, but than the output of the tube amp) Thanks Quote Link to comment Share on other sites More sharing options...
